Home > Technical (L322) > Suspension Fault Max Speed 30mph
RJ333
United States 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Quick update: my solution (swapping dryer) didn't solve it after all. I got the message again. Since I still have the Hitachi compressor I wonder if it might be the ride sensors.
I don't have a code scanner, so perhaps I am off to the shop.
Post #559569 30th Jun 2020 3:27am
Chapeau! Velo
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
A really helpful read as my 08 L322 suspension is behaving in exactly the same way. Great pointer for me to discuss with the indi tomorrow (who to be fair will probably be all over this!)
Post #602857 4th Aug 2021 11:12pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Unnecessary quote removed
I'm also starting to have intermittent issues - who's your indie? (I'm also 'down South'). 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #602884 5th Aug 2021 12:35pm
Chapeau! Velo
West 4x4 in Bishops Waltham
Post #602886 5th Aug 2021 12:57pm
RR2B
Thumbs Up I’ll be interested to hear the diagnosis - keep us posted. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #602888 5th Aug 2021 1:02pm
RR2B
Any update? 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #605928 8th Sep 2021 1:09pm
Chapeau! Velo
Of course! A simple fix; a new front drivers side suspension strut owing to a leak / split in the old one. Essentially the compressor was working overtime to keep the system full of air owing to the leak and shutting down when it got a bit hot. All good now.
Post #605929 8th Sep 2021 1:13pm
RR2B
Thanks for the update. Was your front corner sinking overnight? Still trying to get to the bottom of my issue - intermittent faults are the worst! 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #605930 8th Sep 2021 1:19pm
Chapeau! Velo
The whole car would sink when stationary and engine off, not just that corner, presumably owing to all the air in the system escaping via the split.
Post #605931 8th Sep 2021 1:22pm
Fred
Suspension problem
I have the same suspension problem, can you send me detail of your repair guy
PaddyR wrote:
I did get it fixed eventually thank you.
Even though it was still under warranty I finally gave up on the garage I bought it from + the main dealer who they were sending the vehicle to in order to try and source the fault. Was costing me huge amounts of time and causing endless hassle as never knew when the suspension would start acting up and leave me stranded far from home.
Went to an independent Land Rover specialist who within an hour had identified the possible causes, which were:
1. Software may not have updated when the suspension compressor pump was replaced thus causing the pump exhaust valve to stay open and deflate the system. Apparently it is common for those installing new pumps to forget or not know this is required. So they updated the software and that solved problem number one.
2. Compressor pump was still running unnecessarily, thus overheating, and cutting out altogether. This was shown to be caused by a faulty front right side height sensor. The garage replaced both front height sensors and that was problem solved thank God.
All I can say from my experience here in Ireland is that you need to find yourself a garage who has the knowledge to find and fix the faults in these vehicles.
In hindsight I can't believe how clueless the mechanics at the main dealer were.
Post #611643 4th Nov 2021 11:42pm
RR2B
Eventually got to the root cause of my 'cross-articulation algorithm' fault - replacing the n/s/r height sensor has done the trick. Odd that it did not come up with a specific height sensor fault code though. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #619874 13th Jan 2022 8:04pm
