![]() | Home > Technical (L405) > Entering extended mode |
scotsjon Member Since: 02 Mar 2021 Location: highlands Posts: 44 ![]() ![]() ![]() |
Edit: has entered extended mode |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7980 ![]() ![]() ![]() |
When it tried to lower, it sensed it wasn’t lowering fast enough, or it didn’t get to the desired lowered height. It then decided that this was probably due to an obstruction underneath, so went to extended mode so you stood the best chance of driving over the obstruction... that wasn’t there....
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
This is usually caused by the exhaust filter on the compressor blocking up (they all do it eventually). This slows the release of air to such an extent that the car thinks you're grounded (as the car isn't lowering fast enough) and sends itself into extended mode to try and clear the obstacle.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
Whilst the compressor is exhaust valve is the most likely suspect for you, I had this problem on my old Sport and it ended up being the front offside shock that was knackered and unable to compress when going into access mode. Kev
Thanks for the input guys, TBF it hasn’t done it since, I will let it develop further before I start taking action
Sounds like a plan. Don’t poke the tiger 🤣🤣
