![]() | Home > Maintenance & Mods (L322) > Power steering fluid - clear up an arguement |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Having 'discussions' with a colleague at work regarding power steering fluid for his TD6 hes recently bought. Hasnt been looked after but he got it for a steal. He ordered some PS fluid as it was low, ordered from ECP using their number plate option and it recommended:
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
For what it's worth l think eurocarparts are wrong to list that product as suitable for use in L322 Td6s. It wouldn't be the first time they have listed items incorrectly. |
Thanks guys - kinda what I told him. Plus do engine oil change, diffs and transfer box oils too along with the obvious filters etc
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7994 ![]() ![]() ![]() |
In the Wiki there is details of the recommended fluids....
Thanks mjdronfield
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4346 ![]() ![]() ![]() |
Got cold climate fluid for my 2011 from Advanced Factors
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
My power steering fluid is all over the A66 in Cumbria !!!
Yes all 322's use the "Green stuff" and should NOT be mixed with red! As said above, this will kill the seals in your rack and that is £1000 + |
Thanks again guys, and wogger am gutted for you, hope all is sorted soon |
Re my post above, and just hijacking this thread slightly, here’s me assuming it’s the steering pump that’s packed up. It was Lady Wogger who was piloting at the time, she said the steering went heavy, we pulled up straight away, and as I looked under the car, fluid was |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3329 ![]() ![]() ![]() |
I bought a 5 litre tub of power steering fluid for my L322 from Smith & Allen in Darlington.
I'd top it up and get someone to start it and rock the steering gently whilst looking under the bonnet to see if you can see where it's coming from. There will be a high pressure pipe from the pump to the rack, there will also be a low pressure feed from the reservoir to the pump and a return from the rack to the reservoir. If the oil is all over the front of the engine it probably won't be the rack so it could be a pipe or the pump. With oil leaking and a fan moving air around it'll blow oil everywhere so I'd try having a look with it topped up and running to see if you can spot the leak. David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
I’ll try that mate, that is when I get the |
