![]() | Home > Technical (L322) > Remote fob without a key... |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Yes, a locksmith or auto locksmith can easily cut a new blade using your existing blade as a template. |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 265 ![]() ![]() ![]() |
Yep, but will they have the blank blade to fit in the 2011 RR key fob? |
If the same as in the below video, yes, standard part, nothing special. |
Yep, the remote still operates the central locking. No idea how they lost the blade. |
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 ![]() ![]() ![]() |
The transponder is what allows the key to turn in the ignition.
I can't quite work out which bit is the transponder but just taking the circuit board out of the damaged fob is enough to unlock and start the car.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
The scenario may well be similar to one I had. Lost the key, but the cost of a new one from JLR was |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
The 2010+ cars don't have any option for turning the key in the ignition as they're push-button start.
