![]() | Home > Technical (L322) > Intake pipe (I think) loose and covered in sooty oil |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
A few posts on here about this. Common to be a little loose. I replaced mine as part of preventative maintenance program. Remove the metal clip, tighten it by making smaller and refit. See if that helps. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
I agree with Rob about it being common to be a little loose.
4040 Member Since: 19 Sep 2019 Location: Cornwall Posts: 44 ![]() ![]() ![]() |
Mine was the same when I did the oil cooler seals. It was and still is ok and not causing any problems. |
