![]() | Home > Off Topic > Draper Welder |
| Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929
Anyone on here into welding. Looking at buying myself another welder after the shebeast stole my one as I need too weld the trailer up.
| andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 367
You'd get that something like just using jacks, timber and a big hammer, it just needs something heavy parking on it to counteract the lift.
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
Deleted |
| Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238
A big +1 on the above post. |
Cheers for the advice. I've got a friend who does welding so he's going too oversee the trailer side of it but as you said get some practise in which is pretty much the plan.
| Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226
As said before that will straighten out, just need some secure fixings and work in each plain first ie horizontally and then vertically will come back.
| bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344
Regarding the specific welder listed, I would not buy that. Poor duty cycle and only 4 power settings and it doesn't look like a euro torch either. Better off buying a better quality machine second hand. Bish.
Deleted |
Once you get your welding machine Bean, get some scrap bits and practice, practice, practice, that is the only way to gain some proficiency, having a mate to show you the ropes is good. |
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1422
Lincoln bullet best stick welder ever made |
Think the esab rebel might be out of my price league mate at £1200 upwards 😆 |
| Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 83
If it's for occasional use , Rohr welders get thumbs up from highly experienced welders . Their small , I should say absolutely tiny and lightweight 140 and 160 amp arc welders get great reviews and cost way less than £100 . They have one which has arc leads and tig leads , just need to buy tungsten tips for the tig lead . Check them out for yourself . Folk say you don't need more than 140 amps for welding cars . Some reviewers say they work fine on 4mm , 6mm plate .
Cheers andra. That's good too know |
| All times are GMT |
