![]() | Home > Maintenance & Mods (L322) > Rust prevention underneath |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35782 ![]() ![]() |
i'd be tempted to use this stuff..paints straight on to the rusty bits and you'd probably wont have to wire brush it..
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
As in above post |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 340 ![]() ![]() |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
Raptor is sturdy stuff as long as the corrosion underneath it isn't still spreading as you'll not notice it until its eaten away the steel beneath the coating.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
As a X Defender owner, I second everything above its all down to the prep, especially if you are using some of the more permanent solutions as you’d never spot the rust creep until it’s too late.
