Home > Maintenance & Mods (L322) > Need Side Steps... Aluminium or Steel?
mjdronfield
So, like tends to happen, my factory fit side steps are pretty much jiggered and rusted through.... they are crunching when I get in an out, so will shortly give way 🤣.
Should I replace with aluminium ones or steel ones?
I know the steel ones will be stronger.... but the aluminium ones won’t rust and rot again...
What you folks recon?
Aluminium ones here... might be cheap and iffy.....
https://www.ebay.co.uk/itm/201827605528?fi...SwdjNZGsMD
And some, I’m guessing steel, ones from Direct 4x4....
https://direct4x4.co.uk/collections/range-...ud-flaps-1
Thanks
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #603721 13th Aug 2021 6:40pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
LRParts.net would appear to offer both versions at around the same price point, but they do say in their description that the more expensive version you mention is also alloy.
Personally on an older vehicle I would go with what works and looks OK now, ie LRParts.net £150 version (never had a problem with their service and patience over the phone).
Best Rich L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #603724 13th Aug 2021 7:50pm
mjdronfield
So they do...
Think I need to have a crawl underneath and see if I can undo the existing bolts...
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #603725 13th Aug 2021 8:25pm
Steel will rust but the aluminium will corrode so they will both have a limited life.... Thumbs Up Pete
-Click here for Thread-
Post #603727 13th Aug 2021 9:10pm
mjdronfield
Cheers Pete. Been here before haven’t we 🤣.
There are some for £150 but missing new bolts.
I seem to think the bolts were 6 and 8mm from last time, but might be wrong. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #603728 13th Aug 2021 9:15pm
mjdronfield
Just ordered a pair of the below from LR Parts.....
They had some with missing bolts and fitting kit, which I don’t need, so got some for £150 plus VAT....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #603782 14th Aug 2021 4:31pm
RichM63
Nice one! Thumbs Up L322 3.6 TDV8 Vogue. 07MY
Post #603790 14th Aug 2021 6:13pm
Lots of penetrating fluid, daily, for a week before you swap them, if they snap off they will be a PITA to sort... Thumbs Up Pete
Post #603805 14th Aug 2021 11:03pm
