Home > Maintenance & Mods (L322) > If you service your own L322 read this...
I was chatting to a few mechanics yesterday who had congregated at my mates garage and it became clear that changing the oil in the front and rear differentials on the L322 is different than most cars....
I'm a sad git and have read the workshop manual, my OCD means I have to know how my cars work...!
This is the statement that could cause problems....
I don't know how much, if any, damage it will do running with too much oil in the diffs but they have said it for a reason...
It might be worth mentioning this to your mechanic if you let a garage do it....
This applies to all the L322 models I have a Workshop Manual for but check you own model before changing the fluid.
This does not effect the L405 where they went back to the old way....
Thumbs Up Pete
-Click here for Thread-
Post #603358 10th Aug 2021 11:14am
Merchy
Handy info Haylands Thumbs Up
I have seen many incidents over the years where people have over filled engines and other pieces of equipment.
Said machinery will be designed so that the correct amount of oil will be cooled during operation. Usually through things such as contact with the equipment casing which is then cooled by air.
Too much oil results in too much energy in heat form to be dissipated in this manner, thus the temps rise leading to problems with said machinery.
Even with an oil cooling system, excess oil can overload the equipment's oil cooling capacity.
Whatever equipment you are re-filling always find out the correct amount the makers reccomend.
Post #603368 10th Aug 2021 12:52pm
Cmanbossman
When doing my diffs I found that filling to the point that it drips out is almost exactly the same volume as the recommended volume of fluid.
Intriguing.
Post #603674 13th Aug 2021 7:16am
ur20v
A Trap
Deleted
Post #603676 13th Aug 2021 7:42am
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Just the same as the D3 not really an issue just put the recommended amount in then all
Is ok 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #603731 13th Aug 2021 10:11pm
I guess you only come unstuck when you cannot get the recommended amount of fluid back in Laughing .
Post #603753 14th Aug 2021 9:58am
There are dry fill and wet fill quantities too to beware of in the book.
If you are getting a garage to do it it’s worth buying and giving them the correct quantity of fluid and telling them that it’s the proper volume and won’t fully fill the diff….. There is nothing that can't be fixed with a hammer😜😜
Post #603813 15th Aug 2021 8:11am
