Home > Maintenance & Mods (L322) > 2012 TD8 Westminster, starter clicking
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
Cool, if you continue to have starting issues then do investigate resistance SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #603557 11th Aug 2021 11:49pm
Burkie33
Thanks for all of your advice 🙏, if I have to check out the electrics I’ll beg your advice please………I. Fine on mechanics, welding and rebuilding but electrics are my nemesis……….I’m only concerned about things I can’t see …..like Ghosts and electricity 😂😂🤙🤙 Hi, I’m Burkie……I’ve had this Westminster TDV8 for around 3 years and love it ( apart from when it’s misbehaving) . I have been a LR fan since the early 70s and drove 110s till I bought this Range Rover ( needed a bit more comfort as the years go quickly )
Post #603565 12th Aug 2021 7:56am
mjdronfield
I think it was found that the ends of the copper contacts in the starters carbon up (go black) and this tends to make them intermittently give the click and no start. I don’t think you can buy that bit separately like in the olden days, as it’s a complete unit.
A few on here have took the old starter apart and machined the black off the wires and full service was restored.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #603569 12th Aug 2021 9:34am
Burkie33
Thank you, I saw a YouTube video where the starter was rebuild in that way and it sure would save a few Bob……I have a new Denso arriving today at £290 from our local car component shop……..so hopefully I’ll be problem free once I fit it. I was totally confused by the hard / soft pedal till the servo bleed off system was explained, until then I was trying to remove the panel beneath the steering wheel to check out brake light and any other switches that might be hiding there. Also some Logic in one reply stating that………if there was a switch on the brake pedal inhibiting starting then the solenoid wouldn’t be getting a signal so wouldn’t click 🤔🤔🤔🤔 fingers crossed 🤞🙏🙏🙏🙏🙏 thanks to all who have given me advice 👏👏👏👏👏 Burkie33 Hi, I’m Burkie……I’ve had this Westminster TDV8 for around 3 years and love it ( apart from when it’s misbehaving) . I have been a LR fan since the early 70s and drove 110s till I bought this Range Rover ( needed a bit more comfort as the years go quickly )
Post #603572 12th Aug 2021 9:51am
garyRR
The clicking when starting is characteristic of your starter motor failing.
So, time to get it replaced.
You have a couple of options:
1. Buy a refurb and return service of a genuine one
2. Buy a new OEM one. There's some cheaper ones (e.g. Nissen) out there but something like the Denso is typically what's fitted as a 'genuine' one 2015 Range Rover Autobiography 4.4 SDV8
Post #603573 12th Aug 2021 9:57am
Burkie33
Thanks GaryRR, Denso arriving today at £290, I’d rather fit a decent one and give my lady some peace of mind, she refuses to drive vehicles that have problems …..she doesn’t consider them to be friends 🤔 🙏🙏 Hi, I’m Burkie……I’ve had this Westminster TDV8 for around 3 years and love it ( apart from when it’s misbehaving) . I have been a LR fan since the early 70s and drove 110s till I bought this Range Rover ( needed a bit more comfort as the years go quickly )
Post #603574 12th Aug 2021 10:04am
DanPoole
United Kingdom 2012 Range Rover Autobiography TDV8 Orkney Grey
Where did you get the new one from Burkie? I’m having the same issue so would rather get it sorted before it fails entirely! Have read it should be replaced with Denso dsn1207, would that be correct?
Post #603645 12th Aug 2021 8:57pm
garyRR
The cheapest starter motors are around £200.
Denso is OEM standard. Cheapest place you'll probably find it is Advanced Factors (£285 I think). AutoDoc are even more expensive than that so, AF are probably your best bet. 2015 Range Rover Autobiography 4.4 SDV8
Post #603648 12th Aug 2021 9:08pm
Burkie33
Hi Dan, I got a Denso DSN 1207 from our small town car component shop, delivered to them the day after I ordered it ( and generally this postcode has delivery issues as it’s considered “remote highlands”…….it was £290 and they want the old one back……..but I agree with your sentiments, best to use a good one and get some mileage out of it. I’m going to fit it today so will update you once it’s done if you wish….Burkie Hi, I’m Burkie……I’ve had this Westminster TDV8 for around 3 years and love it ( apart from when it’s misbehaving) . I have been a LR fan since the early 70s and drove 110s till I bought this Range Rover ( needed a bit more comfort as the years go quickly )
Post #603673 13th Aug 2021 7:13am
DrRob
Use Advanced Factors.
Click on your engine:
https://www.advancedfactors.co.uk/engine-components-56-c.asp
Select Starter Motor section
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #603677 13th Aug 2021 8:04am
DanPoole
Thanks all Thumbs Up
Post #603678 13th Aug 2021 8:11am
Burkie33
Hi Range Rover lovers, I fitted my new Denso £290 today……all day 🥴……Iused a 4 post ramp that was eas6 to get all the shields and bolts out. However getting the starter out wasn’t that easy. I jacked the body up further and was able to “ tease” the unit out the off side……..I had to “fiddle” the starter so that from the off side, the soloniid was horizontal add to the rear of the vehicle…….it’s all done now and running, but honestly I couldn’t say how I got the Censored out……….but once it was out the replacement went in a wee bit easier………….my praises to the guys who did this on axle stands ……..my hat it off to you……….Thank you all for your advice a nd support, it means a lot……👏👏👏🙏🙏🙏🙏 Hi, I’m Burkie……I’ve had this Westminster TDV8 for around 3 years and love it ( apart from when it’s misbehaving) . I have been a LR fan since the early 70s and drove 110s till I bought this Range Rover ( needed a bit more comfort as the years go quickly )
Post #603732 13th Aug 2021 10:18pm
DrRob
Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #603746 14th Aug 2021 8:14am
