![]() | Home > Technical (L322) > Fluctuating revs ! |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 190 ![]() ![]() ![]() |
Hi all, a few weeks ago my 3.6 came up with restricted performance when driving at 50mph, went down to about 40mph max speed, also flashed up drive carefully EBD not working and traction control not working. Pulled straight over and stopped, restarted engine and car drove 17 miles home normally.
Forgot to mention in my previous post that the problem with the car only happened when I was driving home from work, same roads there and back. Drove perfectly going to work yet revs up and down when going home, also started to get a slight misfire and black smoke when I put my foot down.
It did indeed solve the problem,as soon as the pipes were changed the problem disappeared. Hope you get your issue sorted. |
