Home > Technical (L322) > 2012 4.4tdv8 electrical problem
longd
Hi guys,
everything absolutely fine went out to drive my car this morning and click click ...
battery complete dead...
charged battery up...
starts perfectly...
check voltage at terminals ---- as suspected not charging !!
checked the belts there intact ! I can only assume its the alternator ??
also I changed the interior courtesy passenger foot lamp and of course I managed to bridge the live and neutral ... now all the courstey lamps are dead , is this a fuse and if so does anyone have the location of the fuse as I can't seem to find it I had a look in the glove box and all the fuses seem intact im hoping I haven't fried a module !! any pointers ??
Post #603733 13th Aug 2021 10:54pm
rjff
Does sound like an alternator problem. BUT, anything give you a clue berforehand?
WM and owners manual is in the Wiki and should give you the fuse details. Cheers
Richard
Gap IIDBT
Post #603734 13th Aug 2021 11:03pm
PeteT80
Interior lights should be fuse 57 behind glovebox.
Post #603735 13th Aug 2021 11:06pm
longd
I checked fuse 57 and it is perfect !! when I pull it I loose the rear interior light and glove box light !!
absolutely no indication of any charging problem beforehand , hasn't missed beat at all, literally jumped in today and dead, new battery bought last October , have literally had no probs with charging system till now !
Post #603736 13th Aug 2021 11:12pm
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
Re: 2012 4.4tdv8 electrical problem
longd wrote:
Hi guys,
starts perfectly...
pull out the BMC connector on the negative terminal and check, this disables the smart charging function. If it charges @13.5 volts then further investigation is required else alternator SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #603737 13th Aug 2021 11:24pm
longd
without sounding like a Censored when you say bmc connector on the negative , im not sure I follow you ... im not at the car this moment... I assume this might be obvious if I was looking at it ? is this bmc connector on the battery negative lead ?? sorry if im completely off !!
Post #603738 13th Aug 2021 11:35pm
longd
I pulled the BMC Connector from the negative terminal ,Still no charge at all!!
The interior lights are all working again (I assume I tripped a relay in a module- obviously reset itself when I disconnected the battery)
Post #603747 14th Aug 2021 8:26am
ffrr14
Sounds like the alternator then SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #603758 14th Aug 2021 12:36pm
longd
Yup I believe you are right!!!
I had a quick look at the where the alternator is located …. looks like a mega ball ache to get to !!!
I assume the fan etc all has to come out as I don’t see any other way to get access!!! I’ll have a look at the wiki to see the Manual !
Thanks so much for the help guys !!
On a side note which way does the fan nut undo ? On uk car does it undo towards the passenger side or drivers side ?
Post #603801 14th Aug 2021 9:34pm
PeteT80
Post #603802 14th Aug 2021 9:50pm
longd
Awesome link !! Thanks so much
Post #603806 14th Aug 2021 11:26pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
HI, worth checking that the one way clutch inside the alternator pulley hasn't failed. THe alternator will not charge very well if it is coasting. I had this happen on a non-charging wife's Polo once.
Post #603821 15th Aug 2021 11:37am
GraemeS
Australia
IIRC the pulley is a fixed version. A son shoe-horned a new 4.4 TDV8 alternator to his 3.0 TDV6 D4 and had to fit a free-wheeling pulley for the TDV6.
Post #603824 15th Aug 2021 12:05pm
longd
Just waiting on hose clip pliers to come and will pull out the Alternator. Will report back my findings
Post #603894 16th Aug 2021 9:11am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Not sure how easy it is to get to live feed from alternator but if not too bad could you not just disconnect, isolate and insulate the wire , recharge the battery and see if any drain? This would definitely confitprm if you have a dead c short in the alternator before you have to remove and change it. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #603895 16th Aug 2021 9:55am
