![]() | Home > Technical (L322) > Adaptive headlights / cornering lights not working. |
| suburbanspaceman Member Since: 10 Aug 2021 Location: Burton On Trent Posts: 31
Hi,
I seem to remember way back when that factory ran out of ECU's so simply didn't fit them in thousands of models of a close age to yours sir... |
| kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335
Does your heated steering wheel work? Odd question but the heated steering wheel and adaptive headlights are powered by the same relay. If the heated steering wheel works then the module is likely to be getting power and it would hint at a dodgy module or somethibg downstream of that. Have you got a code reader and the AFS system does produce fault codes? |
| Rockysev Member Since: 30 Jul 2021 Location: Cornwall Posts: 6
Thanks for the replies everyone.
Ive a spare working module you could borrow for the price of postage if that would help? |
Hi Kezbo,
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
are you sure you want to get these working?
Hi Stan,
Fitted the replacement module yesterday evening. The lights did a dance on start up which they haven't done in my ownership. Thought this was a good start but the dash warning light flashed continuously and on a short test drive i didn't notice any difference.
| matthewbolton90@gmail.com Member Since: 12 Apr 2022 Location: Bedfordshire Posts: 1
Hi Sorry to pull up an old post, I’ve just bought an ‘06 Vogue from a family friend knowing the heater steering wheel and adaptive light warning is flashing consistently, can you advise any further on this? Thanks in advance |
| All times are GMT |
