Home > Maintenance & Mods (L322) > 13% throttle position at idle
Danwilderspin
I was looking at my iid tool for something else and spotted that my throttle position is reporting 13% even with the pedal not pressed is this normal? Is this the percentage the butterfly opens as opposed to the pedal?
Also the accelerator pedal sensors 1 and 2 also show 13% Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #603463 11th Aug 2021 12:13pm
IIRC last time I looked at mine on fatty offroader is was around there, what you should check is that it gets to 100% when you floor it, my pedal was worn out and it only got in the 80's, made a noticeable difference with a new one..!!! Thumbs Up Pete
Post #603479 11th Aug 2021 2:23pm
Danwilderspin
Oooh ok! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #603542 11th Aug 2021 10:13pm
gravitylover
United States 2006 Range Rover Supercharged 4.2 SC V8 Alveston Red
Mine also runs at 13.7% at idle. I never thought to check load and such at WOT but will tomorrow.
Post #603547 11th Aug 2021 10:40pm
Danwilderspin
Did you check the load?
I checked mine on iidtool and snap on solus and get the same:
Throttle position sensor 79 max dropped to 50ish at high revs for a brief moment
Acc pedal sensor 1 and 2 81% all the way down but now kicking down, 90% kickdown on
Is this normal or not for a 4.2? Would be great to hear from some of you guys - you don’t even need the car running to test I got the same results driving and not driving.
Would the throttle position be linking to the pedal position? Interesting it’s lower than the pedal?
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #604117 18th Aug 2021 6:04pm
Danwilderspin
Hmmm looks like this could be normal I wonder why though?
https://www.fullfatrr.com/forum/topic19329...e+position Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #604120 18th Aug 2021 6:16pm
