Home > Maintenance & Mods (L322) > range rover letters
Powerfully sell them ====================================
Post #57984 31st Mar 2011 10:47pm
pretlove
Re: bonnet letters
reynolds wrote:
Has anybody got one of the wheels advertised on flea bay that they have user to either sell or lend me cheers
i got one of those from my local paint supplier i just cant find it at the mo sorry if i do ill let you know "RANGEISM WILL NOT BE TOLERATED"
Post #57987 31st Mar 2011 11:01pm
Mudplugger
England 2016 Range Rover Vogue SE SDV8 Waitomo Grey
The solvent that best breaks down the glue for these badges is xylene.
It also gets tar spots off a treat.
Hammerite thinners is mostly xylene - so you can use that if you can't get a tin of the pure solvent.
Highly flammable so no smoking or sparks nearby.
Will strip polish off a vehicle, so be careful.
Won't damage paint though.
I got a 5 litre tin free from an industrial paint supplier at the same time I bought a 510 litre drum of red oxide.. I must have had it 6 years and still plenty left! Wink Range Rover Vogue SE SDV8 - L405 (now sadly sold)
BMW i3 (fantastic little runabout)
Kioti NX6010 Tractor
Yamaha Big Bear ATV
And a whole heap of other kit...
Post #58574 3rd Apr 2011 8:04pm
Austin
England 2004 Range Rover Vogue Td6 Java Black
the best stuff to use by far is "Autoglym instant tar remover" and its safe on paint too, will remover anything stuck to your paint.
Post #60376 14th Apr 2011 6:11pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
its really easy, i used a hairdryer to warm the glue/plastic up then used a very thin plastic scraper to carefully slide under the letters then used the removal wheel to get rid of the glue (works brilliantly!!! cant recommend it enough!) then a bit of polish to clean the paint work, not one scratch in doing this!
Matt
Post #60409 14th Apr 2011 10:23pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Same method works for getting dealership stickers off the back window too........................ and removing the FULLFATRR.COM transfer that the cold weather this winter reduced to LFA TA. M on my rear screen! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #60418 14th Apr 2011 11:50pm
