Home > Technical (L322) > Map sensor
Sean
England 2007 Range Rover Vogue SE TDV8 Java Black
Map sensor
My car occasionally goes into limp mode and clears immediately when I switch off and back on and then runs fine. I have had the codes read and it’s coming up with the map sensor on the inlet manifold. Any ideas please where I could get a new one. I used to get my landrover stuff from advanced factors but they don’t seem to list them. Unless I have missed it which is quite possible
Thanks
Post #604283 20th Aug 2021 4:17pm
GraemeS
Australia
Have you swapped the left and right sensors to see if the fault swaps sides?
Post #604303 20th Aug 2021 9:53pm
also have you tried cleaning it.. ... - .- -.
Post #604305 20th Aug 2021 10:12pm
Sean
Thanks Stan will give it a clean
Post #604350 21st Aug 2021 1:13pm
