![]() | Home > Technical (L405) > What’s making the whooshing sound? |
| knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782
Glad you got it sorted |
| goddo Member Since: 27 Oct 2020 Location: south Posts: 84
That racket must have driven you nuts. Glad you got it sorted. |
| L405RRAndy Member Since: 28 Jun 2021 Location: Essex Posts: 2
Has anyone managed to get to the bottom of this or find out any more info?, mine makes the exact same noise 2015 SDV8, bought it at 80k and now on 86k noise is no better or worse, replaced all the belts, tensioners + alternator and still no difference. Definitely something inst right, more pronounced on trailing throttle 1100-2000 rpm, Thanks Andy |
| FF777 Member Since: 21 Jan 2022 Location: London Posts: 17
Anyone had this diagnose? I've got exactly the same issue |
Hello again
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758
Thread resurrection but... did you ever figure this one out LT?
| LT Member Since: 13 Mar 2017 Location: South West Posts: 417
No, it is still there and variable between hardly noticeable at all to how it was when I first noticed it.
Thanks for the reply LT.
Tis usually the cover under the gearbox... There is a 2mm thick metal bracket with a tin temperature resistant aluminium cover that spans most of the plastic gearbox sump... The metal bracket usually fails by cracking! Only way to diagnose it is to remove the 4 10mm bolts that hold the aluminium cover on and inspect the bracket above... |
| SamDubs Member Since: 26 May 2023 Location: West Midlands Posts: 2
I have also had this exact cooing/whooshing/resonance issue for the last 18 months (2017 SDV8), so have been following closely.
The broken brackets make the kind of resonance you would hear in a bus or a plane. Not a pigeon coo’ing noise BUT… Noises are very subjective! Well worth checking the bracket/cage has not fractured sir… |
Cheers for the quick reply. Maybe the pigeons are different here in Worcestershire... |
| evotime Member Since: 02 Apr 2021 Location: Aberdeenshire Posts: 136
Possible cause is the Torque convertor oil pump blocked/ falling or possible low oil level in gearbox making the pump struggle.
Oil pump has been changed for a new one and gearbox oil has been drained twice (as much as is possible) and refilled to the correct level.
| All times are GMT |
