![]() | Home > Maintenance & Mods (L322) > suspension mods |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Have anyone done or seen suspension upgrades on 2011/12 AB? I have a heavy Tintent? we all know that it has a towing weight limit of 3500kg but that is pulling not weight load on the tow ball which is 150kg?
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1321 ![]() ![]() ![]() |
I think the only thing you could do is make sure all the suspension joints are in good nick. If there is any slack the car body will move unnecessarily side ways before the movement is transferred to the car tyres.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
I have towed a large tin tent, 2000 KG’s for meany years with no issues. Are you loaded correctly with your trailer and do you have your tyre pressures set for towing on the fatty? Also the lower profile tyre you run, the more stable the outfit will be with overtaking ETC.
My thinking was the same as many others about the loading? When I collected the caravan (empty) still had sway so much so on a very bad section of the M40 the ATC kicked in? speed was 64mph on a downhill which is not ideal but should have handled it? the unloaded weight of the caravan is 1800kg.
Have you actually checked the nose weight? My new to me twin axle has a stupidly heavy nose weight compared to the single axle it replaced so I would doubt yours would be to light. Could it be it is to heavy at the front? |
Hi, Mine is a twin axle I have moved some weight on to over the axles the front only has a 9kg gas and a small gas bottle not much in the lockers upfront so my next step will be to double-check the tire pressures and replace the rear bushes on the car?
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Make sure you don't have to much weight at the arse end of the van - will waggle like crazy.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2711 ![]() ![]() |
Too front heavy won't cause swaying whereas too light will, as will the van not being level. |
Hi, what I have forgotten to mention is that I have towed the same caravan with a different car and no problem?
Not trying to teach you to suck eggs but have you cleaned the pads in the caravan tow hitch? Have to clean mine every second trip to stop the incessant creaking! I don't think they would stop a two ton pendulum from swinging side to side though. |
ikjos Member Since: 09 Sep 2019 Location: Hornindal Posts: 41 ![]() ![]() ![]() |
Just a small video that shows the dangers with wrong weight distribution on a trailer.
Thanks for your help guys |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 123 ![]() ![]() ![]() |
HI, have you checked that the caravan hitch looks slightly low when the whole outfit is loaded ready to go? Some caravans when loaded sit too low at the back, and you are towing with load only on the rear wheels of a twin wheeler. For example, I once bought an Ifor Williams 16ft twin wheel trailer with a 40ft cherry picker mounted on it. I moved the main body to the front of the trailer, but it still had 10ft hanging out the back. I had it on a Discovery TD5, thirty MPH along the 40 foot river from Ramsey to March, it was bouncing the front wheels of the Disco off of the ground. A bit scary, as the river was full of left hand drive volkswagens at the time. Imagine having knackered dampers on the towing vehicle! |
Fixed it? The towing problem was as I thought the rear hub bushes were stuffed? They looked good from the outside but once removed I could feel that they were stuffed.
