Home > Maintenance & Mods (L322) > L322 2010 rear seat
Landmark
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
L322 2010 rear seat
Hi just gone to collapse rear seat and button pressed on and stayed in without releasing seat. Does anyone know of a quick cheat to get it up or is attempting to take hinge off a possibility?
Post #604442 22nd Aug 2021 1:05pm
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
A thump backwards on the backrest? Sit in the seat, have a shuffle around & then try the latch again to see if it has returned to un-pressed?
When / if you release it tip the whole lot forward & make sure the 'pads' where the supports for the seat bases sit are clean & unobstructed. Think anything there causes the seat to be a tiny but too high & for the backrest latch to bind.
Post #604452 22nd Aug 2021 2:58pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Same here - fiddle around with a small screwdriver from behind to release the catch. There seems to be a metal rod that jumps out from a plastic actuator, you can access this by prising off the plastic cover. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #604468 22nd Aug 2021 5:30pm
Landmark
Seat top release button floppy and not able to release
Thanks all will have a go a bit later and just found a good write up on here as well . Thanks and will report back.
Post #604471 22nd Aug 2021 6:02pm
Landmark
All sorted many thanks.
Seat repair complete and cost nothing .lol thanks for all your help. Indeed the rod had come out, so i put star clip over end and sorted. I Thumbs Up Thumbs Up done the other side as well just in case.
Post #604630 24th Aug 2021 7:13am
