![]() | Home > Technical (L322) > 3.6 TDV8 Exhaust Valve - ALL Replaced. Still Fauly |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2735 ![]() ![]() |
The brass breather on the exhaust line gets blocked - drill a small hole through it. |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
I've removed this. Still no luck, I've replaced everything in the rear spare wheel arch. |
But thanks for the suggestion! |
tezza Member Since: 22 Jul 2021 Location: Gloucestershire Posts: 78 ![]() ![]() ![]() |
Is removing it an option or does it need to see some kind of pressure restriction there. I had a similar problem recently with the 35mph suspension warning and I seem to remember it wasn't happy with the silencer completely removed.
Is there a fault with the electrical supply between the suspension ecu and the pilot exhaust valve?
Sorry, the 3.6's suspension ecu is under the left end of the facia but has the same set of connectors. |
That's the thing. With the previous compressor/ exhaust valve I tired it installed/ removed. No difference. This one actually has a hole drilled in it, but I'm going to remove it completely and see does it make a difference with this compressor unit. On the plus side, at least it *sort of maintains height!!! Nonthing worse than bumpstops! ![]() |
I'm going to try this and see if perhaps this is causing the issue. I'm really clutching at straws now! Will report back! |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1395 ![]() ![]() |
Try stripping down the desiccant dryer on the suspension compressor , it may be saturated, you can reuse the beads after heating them up in the oven to regenerate for a couple of hours. |
I actually replaced this part when I swapped over the compressor unit with a spare.
Here she is.
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
Faulty or broken level sensors can be a problem as they corrode internally if not used for a while. |
