Home > Technical (L405) > Range Rover L405 2014 SDV8 Keeps Blowing Turbos |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3691 |
Could be oil starvation to the Turbo causing them to run dry and then failure. Or has it been given a bonkers re-map by a previous owner. The V8 diesels are normally pretty bomb proof 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
22nd Aug 2021 2:56pm |
dladds27 Member Since: 22 Aug 2021 Location: Oxford Posts: 10 |
I believe oil starvation was ruled out with the secondary turbo failure, and given the engine was running on oil injected into the motor on the primary turbo failure the garage does not believe it to be oil starvation on the primary turbo failure, however we are awaiting the report back from the turbo specialist.
22nd Aug 2021 3:06pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1692 |
New engine and 2 new turbos, or reject the car |
22nd Aug 2021 3:20pm |
New short or long engine indeed maybe required, and most likely two new turbos....however the cost is massive at £15K for a long engine kit from Land Rover refurb (most of which are apparently new). The issue here is who is liable, the dealer or the garage for failing to diagnose the issue from the secondary turbo failure, which seemingly lead to the primary turbo issue and then subsequent engine damage.
22nd Aug 2021 3:31pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
Does the secondary turbo have a twin oil drain? Early 2014 still had a single drain ex factory but may have had a twin drain retro-fitted or if later 2014 may have the factory-fitted slightly different twin drain. |
22nd Aug 2021 9:49pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
Looks like a classic case for rejection ASAP to me, it will save you a world of pain |
22nd Aug 2021 9:51pm |
It has the revised twin drain setup apparently (first thing I checked for when the secondary turbo started smoking). Unfortunately simply rejecting the vehicle is proving tough, especially as dealership is blaming garage for poor diagnosis and subsequent damage. |
22nd Aug 2021 9:54pm |
Which is exactly why I would insist on rejection without delay. Don’t let the dealer fob you off trying to get off the hook with fine details and getting technical He sold you a car it broke down almost immediately, he fixed it and it broke down again, his problem the end.
22nd Aug 2021 10:20pm |
