![]() | Home > Maintenance & Mods (L322) > L322 10 Year Service Cost |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
So…. The independent garage I used for the last 2 or 3 jobs has quoted over £700 for the service this year. Seems a bit excessive I thought.
Ah, I remember the gearbox, sorry, the correct gearbox fluid not being cheap.
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
Hi, I have been costing parts for a 175k service, and reckon on at least that for materials. £105 for gearbox filter and oil, £370 at Landrover prices plus labor. At least a day's time under cover. Change all pulleys and belts, also what else one finds that needs attention. We paid £1700 + for a 150k service on a Freelander 2 a couple of years ago at an independant specialist. Add in brake parts if needed, it soon adds up, then if you have to sub it out add up to £1000 for labor.
I don’t mind spending on it….. given the above, I need to make sure the correct fluids etc are used. I’m not cutting corners on parts…. But happy to get better labour rates….
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
I paid around 550 for a ‘9 year’ B service which included:
1995 4.6 v8, green/tan (long gone) 2005 4.8iS X5, blue/black 2011 4.4 tdv8, black/black (gone) 2003 3.0d X5, Oxford green/black/manual 2021 p575 SVR, BR green/vintage tan |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 301 ![]() ![]() ![]() |
Try Ian Bodsworth for your diffs, transfer box and gearbox flushes. He did mine for a very reasonable sum and he comes to you http://updatesbybodsy.co.uk/. Have used him a few times now from when I had my D3.
Thanks for that. I would prefer someone who can do the gearbox and diff oils properly, so I will look to get in touch with him. If they do a mega flush, do you know how they manage the thermal valve that shuts in the 8 speed box?
I’ve just left Bodsy a voicemail.
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
Bodsy does a top job. highly recommended |
