![]() | Home > Maintenance & Mods (L322) > 2012 4.4TDV8 Battery Charging Points - CTEK |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
Dan
DanPoole Member Since: 01 Mar 2017 Location: Kent Posts: 59 ![]() ![]() ![]() |
Thanks Richard.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Been using the towing electrics for over 5 years with no issues with mine.
Sorry about that Dan.
I also need to work out whether the charger is faulty before hand, as if my charging points were correct originally, the battery didn’t take any charge.
ISTR there are a couple of threads on here about connecting CTek and other chargers, if I find them I'll link. Particularly where to fit so as to be able to access a charging point when the battery is dead and you can't open the door. And that's another advantage of using the trailer electrics, connect, switch on and you have power to the doors etc.
Thanks Richard - I have searched but haven’t come across anything that looks similar! |
I think my 2 plugs are white and grey.
I believe black is for indicators etc, and white/grey is for caravan interior electrics.
You can see how much I know🤣, but done a quick google, and it seems there are 3 main types, black 7 pin, just the basic lights…. Then there’s that plug and another 7 pin, which seems to be white and does the added charging bits for a caravan battery and fridge constant supply etc…. Then there seems to be a more modern 13 pin that seems to have all that but in a single socket…. Which more modern caravans use… not sure what pins my 2 sockets are, but pretty sure I don’t have a black one….
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
Your grey one may be faded black ?
Dan
Good point Alistair…. It may well be faded…. Will look next time I’m out…
@Alistair - any reason you know of why I would have two black plugs? |
