![]() | Home > Maintenance & Mods (L322) > 3.6 TDV8 Alternator failing ?? |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714 ![]() ![]() ![]() |
Any experience of partly failed alternator symptoms ?
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
There's a few threads on TDV8 alternators. The 2007 vintage seems particularly fragile.
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 479 ![]() ![]() ![]() |
My alternator was failing for a couple of weeks - I suspected the battery at first but had a rude awakening on a dark Winter’s evening when I didn’t make it home due to complete failure of the alternator.
Thanks guys - useful additional info !
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
A failing battery or poor terminal contacts will do it as I found. Suggest clean tighten the distribution also (behind the battery)
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 ![]() ![]() ![]() |
Has the car been programmed to accept new battery. There is a list on iid tool to select. I think this helps the alternator coordinate charge cycle times etc. |
Landmark,
