![]() | Home > Maintenance & Mods (L322) > Battery charging |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
I always have & never had a problem. CTEK charger, so can't vouch for others. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Same here, I charge via the towing electrics.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3882 ![]() ![]() ![]() |
I have a Ctek lead permanently wired to the thick red battery terminal in the rear fuse box because I always drive into my garage so it is easy to just open the lower tailgate to pass the lead out in the corner without trapping it , close it up and leave to charge overnight.
Tiny Timmy Member Since: 04 Sep 2013 Location: Bucks Posts: 217 ![]() ![]() |
Thanks for the help guys.
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 ![]() ![]() |
Not advised as it bypasses the battery monitoring system.
Thanks Al, I'll try that. My battery seems ok just wanting to top it up just in case |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351 ![]() ![]() ![]() |
Use your towing electrics (Grey one or the newer 13 pin only; won't work on a single black 7 pin) if you have them fitted.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Sorry for kinda hijacking the thread gents, 2003 TD6. Can I connect a CTEK to the positive and negative posts by the passenger side front suspension mount? There’s a positive terminal on the wall between engine bay and battery compartment and an earth post/stud on the actual suspension mount |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988 ![]() ![]() ![]() |
^^ Yes |
