![]() | Home > Technical (L322) > Ride quality: cvd vs non-cvd |
| Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640
While I can’t comment on the ride between CVD and non-CVD, I will ask how many miles you have on the clock?
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2745
Air-springs themselves provide very little damping so require the shocks to be in good condition to avoid a harsh ride, even more obvious with CVDs because of the smoothing they provide when working as they should.
| RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520
What size wheel/tyre combination are you running?
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345
Sam Langley (on here and YouTube) is exploring this for the exact same issue....
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3325
Can't comment on the L322 directly but on my Audi A6 Allroad with a similar air suspension setup (the shock absorber damping is user selectable unlike the L322) the system works well to smooth out larger road undulations but with road imperfections like ridges, potholes and general roughness like you get on anything but smooth tarmac they do very little and this is down to tyre wall thickness. Mine has 19" wheels and it's as 'crashy' now on rough surfaces at 115k miles as when I first had it at 30k miles. I've often thought of changing it to 17" wheels which were the stock size but as most of my driving is on M-ways the 19's are OK. When I test drove my first L322 TDV8 4.4 on 255/50/20" I noticed the same thing i.e a smooth floaty ride on a smooth road surface but crashy over a rough road surface (and more suspension rattles than my Audi with it). Likely when I get my L322 I'll think about 255/55 tyres as a option. |
| coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
Rob, yep, commented on Sam’s thread on the issue - it’s pretty much identical to mine. He has relatively new front dampers and new rear ones. I also my rear dampers before him which made no difference at all.
| JNC Member Since: 23 Feb 2020 Location: UK Posts: 293
Also interested in this.
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757
I've just logged back in as I received a PM from Sam
Thanks for the reply mate - I had seen your post and glad to hear the ride is good.
Yesterday I was walking down a road with a number of speed bumps spanning the width of the road, and watched as an L405 went over the, with lots of wheel movement and no obvious body movement. The same happened with the newer RRS a few days before.
I suspect that your shocks are worn-out, noting however that the L405 has an upper wishbone whereas the L322 has struts and therefore a direct comparison may not be too indicative.
Cheers GraemeS, my initial thoughts were to replace the ageing struts and the plan was to do that now my rear bushes have been replaced. However reading this threat and a few others, they have casted doubt in my mind. I’d rather not spend £££ replacing struts and finding the ride is still frustrating.
I replaced the rear dampers with bilstein ones (155k miles and on the originals) and it made the ride worse so swapped them back.
| 4040 Member Since: 19 Sep 2019 Location: Cornwall Posts: 44
This is probably not related to your issue, but. I bought my 2012 TDV8 just over 18 months ago.
