Home > Off Topic > New brickwork looks craaap
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Had a small retaining wall and 2 wide steps built last autumn (brickwork to match the house) and it’s started to turn white-ish, I’ve since read its effervescence, I think salt leaving the brick.
I’ve tried cleaning it with an effervescence solution to no avail, what other options do I have?
I don’t really want to paint the wall and steps, any other ways to reduce how bad it looks?
Open to suggestions gents Thumbs Up
Post #605109 29th Aug 2021 1:20pm
p38arover
Australia
Efflorescence can be removed with white vinegar. Probably cheaper than the chemicals you've tried.
Sometimes it can be removed with a high pressure washer but the water might bring more to the surface. Do it on a warm, dry day (if you get those). Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #605114 29th Aug 2021 1:25pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I had a load of it on my wall, I pressure washed it many times and it kept coming back. After a while though the amount reduced significantly until now, theres none. Just keep washing it, it does fade away to nothing. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #605125 29th Aug 2021 6:01pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Spraying water won’t actually help. The white efflorescence arises as the brick expresses salts from itself as a result of the chemical reaction with water. The best thing to do is brush it with a wire brush if it really bothers you, otherwise just leave it and it will eventually disappear once the salts have leached out. There are any number of ‘fixes’ out there and cowboys who will take your money, but anything they sell you will not clear it up.
Post #605197 30th Aug 2021 5:40pm
If the retaining wall and steps are in contact with earth the problem will be exacerbated by the moisture in the earth being absorbed into the bricks and reacting with the brick salts. The problem will go away eventually but in the meantime cleaning with a stiff brush is probably the only way to deal with it.
Post #605201 30th Aug 2021 6:18pm
AJGalaxy2012
Pressure washing certainly washed the white marks away for me, even more so when I used the hot pressure wash. BMW i3 Electric Car
Post #605213 30th Aug 2021 7:48pm
dingg1
Brick acid at your local builder supply yard
Post #605215 30th Aug 2021 8:05pm
chugga90
Brick acid potentially will make salts worse.
Post #605220 30th Aug 2021 9:17pm
dingg1
Brick acid dissolves sodium carbonate, a common cause of efflorescing salts in brickwork.
So says google anyway Cool
Post #605223 30th Aug 2021 9:57pm
Andy S
Yes it washes away the surface salts, but you wet the brickwork and that moisture gets absorbed and draws more salt from the brick, so you’re not solving the problem.
Yes a builders merchant will sell you all kinds of chemicals to ‘cure’ the problem but they don’t really work. You just have to leave it and brush off if you find it a problem. It’s a natural process and does not mean the bricks are dud. It will eventually fully express and won’t be a long term problem.
At least that’s what I learned when getting my surveying qualifications……
Post #605224 30th Aug 2021 10:32pm
AJGalaxy2012
I understand that, I'm treating the symptoms not the cause. I was merely removing the eyesore temporarily when it was bad and eventually flushed it all out. BMW i3 Electric Car
Post #605230 31st Aug 2021 6:08am
mrblonde
Cheers all - few options here so I’ll let it dry right out first and get the missus to give it a damn good scrub with the new brush I bought her recently Embarassed
I’ve got til the spring before anyone’s going to see it anyway, so failing that it’ll be clad over
Post #605386 2nd Sep 2021 9:31am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
It will disappear. Just salts from either the clay used to fire the brick or ground slats from poorly stored bricks. Anything wet to solve the problem will not work.
patience and the good ladies elbow are all it takes. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #605422 2nd Sep 2021 5:27pm
ilard
Is it lichen? I read it’s lichen so using a patio algae cleaner could work. But if it’s the regular sweating of salt out of new brick, as we do, then wait-do-nothing could be a significantly cheaper option. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #605530 3rd Sep 2021 11:17pm
we see it all the time on new house brickwork, generally caused when the bricks are laid wet, or water has been allowed to get into the cavity wall, eventually it will go away through weather action of being rained on and drying. wetting it up will only make it worse, and though brick acid will clean it, it could discolour the mortar and will only be a temporary solution as until all the salts in the brick have leached out it will keep reappearing. Personally I would just leave it alone and give it 12 months to stabilise before doing anything too drastic..
if the back of the wall is in contact with damp ground or is holding water this will definitely exacerbate the situation, as the wall is never fully drying out. There is nothing that can't be fixed with a hammer😜😜
Post #605533 4th Sep 2021 7:35am
