![]() | Home > Technical (L322) > 2012 towing electrics |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
I had the single black and swapped it with
4040 Member Since: 19 Sep 2019 Location: Cornwall Posts: 44 ![]() ![]() ![]() |
Thank you. That’s also why I’m confused. It says plug and play, then it also says there is coding ‘yes’ then all sorts of other conflicting information about reverse sensors and fog lights !
I may be wrong but as yours has the twin electrics the 13 plug should be the same set up just one plug so if the reverse sensors etc work now they should be ok after 2012 Range Rover Westminster 4.4 TDV8
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I swapped over from a two plug to one plug 13 pins? on my 2011 SE? When the car has never had a towing system fitted then it needs to be programmed as was the case for my 2012 AB. |
