Home > In Car Electronics (L405) > Seatbelt warning light. |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 332 |
Could it be a warning that youve got the child safety seat switch set? |
7th Sep 2021 11:35am |
spbee Member Since: 25 Jul 2021 Location: Cumbria Posts: 34 |
what model year do you have ? i cant find a reference to an amber seat belt sign in the handbook, only a red one, is it the airbag warning light ? |
7th Sep 2021 6:43pm |
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 191 |
Not sure of model year , first registered November 2013. Vogue SE. |
7th Sep 2021 10:07pm |
can you post a pic of the light ? |
7th Sep 2021 10:13pm |
Just read it maybe airbag warning light, any thoughts. |
7th Sep 2021 10:14pm |
It’s the airbag warning light. Have you moved the seat around much recently. can be a problem with the under seat wiring
7th Sep 2021 10:16pm |
It’s new to me, so have been experimenting with seat positions. |
7th Sep 2021 10:19pm |
Thanks Guys, great help as usual. Yep, seatbelt sign, loads online, including here. Seems intermittent, some say wiring behind seat back, some say outside temperature, others say the car is haunted because no faults found. But I did find an airbag recall in 2013 for SDV8 models. |
8th Sep 2021 8:16am |
UPDATE......
8th Sep 2021 12:13pm |
no just the one warning light with no indication which side has the problem. Sounds like a loose connection which was what was causing the issue on mine. Id put the seat right back and down which obviously knocked something out of position. Once the seat was back up I had a google and a prod under the seat and everything went back to normal. There is nothing that can't be fixed with a hammer😜😜
9th Sep 2021 7:05am |
