Home > Technical (L322) > Thick White smoke!
ricknayton
United Kingdom 2006 Range Rover Vogue SE Td6 Santorini Black
Thick White smoke!
Big Cry
Apologies for the new thread but wanted some clarity if possible.
My 2005 Vogue started making a whirring noise on Thursday followed by the most white smoke i have ever seen come out of a vehicle.
She is currently up on a ramp and the exhaust has been removed which is full of oil. 6 Litres were put into the engine and i have an idea that it may be the turbo, but thought i would put it out there to see if anyone has had a similar experience. It was the alternator 3 months ago preceded by the fuel injectors 3 month before that so please excuse the tears.
I really have had enough of throwing money at it but i don't want to toss her on the scrap heap, although I said if i did my wife would be in it as well!
Any help/ideas/thoughts would be greatly appreciated as i think it's time to put her to sleep..........and the Vogue!
Thanks
Post #606245 12th Sep 2021 8:36am
Spike
United Kingdom 2004 Range Rover Vogue Td6 Monte Carlo Blue
Did she overheat? (I mean the car!) could be head gasket, cracked head or block, white smoke would indicate steam! Best of luck.
Post #606248 12th Sep 2021 9:01am
dingg1
Classic case of turbo failure Sad
Post #606249 12th Sep 2021 9:06am
ricknayton
Laughing thanks Spike.
No overheating at all - crazy.
Are reconditioned turbo's ok or best to get a brand new? Best place to get one reasonably priced?
Post #606251 12th Sep 2021 9:10am
gettingold
What are you expecting the cost to be if it’s Turbo failure? Hunt for a L405 is on.
Post #606253 12th Sep 2021 9:20am
ricknayton
Probably not far off what the vehicle is worth.
Are you going to tell me different, gettingold?
Post #606256 12th Sep 2021 9:26am
JayGee
Having owned a lot of turbo charged cars.....
White smoke is oil vapour from a leaking exhaust side turbo oil seal which you have already confirmed from the exhaust removal. If it was blue it would be oil being burnt in the combustion chambers which would be more serious as it would be an engine issue. Turbos are repairable depending on how far they have worn and you can buy reconditioned units so it's not necessarily a total disaster esp as if it's a 2005 it will be a single turbo.
Post #606257 12th Sep 2021 9:39am
ricknayton
Thanks Jaygee.
I'm sure mine will be as worn as can be!
I see it's a 10 hour job and removal of the body Big Cry Big Cry
Post #606261 12th Sep 2021 10:06am
TDV8 Paul
Not body off on full fat rangies so at least that’s not a cost to worry about!
I had my turbos replaced for new ones on my tdv8 and that was £3k 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #606308 12th Sep 2021 8:21pm
JayGee
£3K is a good price - where was that and at what miles did they let go?
Post #606310 12th Sep 2021 8:41pm
Merchy
If the rest of the car / engine is ok, you can get a re-furbished turbo for £300, may be worth thinking about Thumbs Up
Post #606312 12th Sep 2021 9:33pm
ricknayton
I think im going to just sell her off. Anyone want any spares Big Cry
Post #606322 13th Sep 2021 6:41am
TDV8 Paul
I got it done at AJ Landrover specialists, they went at 155k one had seized solid, they sent me videos and did a full report, replaced with Borg Warner new units so I was pleased with the job
They said it was caused by an incorrectly fitted oil filter, I saw in the video they sent that it hadn’t been seated correctly and the small locator bit wasn’t located and the filter had just been placed downt and the lid squeezed back on crushing the bottom of the filter
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #606332 13th Sep 2021 9:09am
