Home > Technical (L405) > Rotary gear selector not popping up.
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
Hi Guys,
My 2015 L405 gear selector will not pop up. Without it popping up I can turn to neutral and reverse but not to drive. I can hear a solenoid operating or trying to every time I press the brake pedal.
Searching on line sounds like there are other Land Rover models with rotary gear selectors with similar types of problems.
Is there a common fix for this?
Thanks Paul 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
2000 P38, Gen3s, 2 inch lift, KM2s 285/75/16
Post #606241 12th Sep 2021 7:30am
CS
Mine was replaced under warranty when it stopped moving freely, and squeaking, so maybe replacing the unit is "the fix"? Only Range Rovers since 1988
Post #606266 12th Sep 2021 11:08am
sounds like the solenoid is failing..you will probably need a new rotary gear selector module.. ... - .- -.
Post #606273 12th Sep 2021 12:24pm
Hammer
Thank you Gents
will order one today 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
Post #606320 13th Sep 2021 1:24am
Hammer
Okay it’s arrived from UK to Perth Western Australia, takes four days to get here sits at airport arrivals for another four days.
Amazing. if we order anything from the eastern states of Australia can take two weeks.
Anyone know what’s involved for replacement?, so far researching looks like I need to remove the entire console 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
Post #606884 20th Sep 2021 11:44am
probably other videos on this and off course theres the WM.. ... - .- -.
Post #606886 20th Sep 2021 11:47am
Hammer
Thanks Stan, but it’s actually entire module I need to replace. 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
Post #606888 20th Sep 2021 12:02pm
CS
When mine was replaced the console was removed. Be careful not to scratch the lower glovebox leather in the process. My dealer did that, confessed and replaced it too. Only Range Rovers since 1988
Post #606947 20th Sep 2021 8:15pm
Hammer
Thanks
Just replaced mine over the weekend, purchased from island 4 x 4. Had to remove the Centre console cover, taking my time the job took six hours. Online there’s a video on how to remove the 2019 L405 console but it is slightly different to my 2015 main difference was 2015 has 2 screws plus clipped down and arm rest has a long pin. 2019 6 screws plus armrest screwed down.
If I was to do it again I reckon I can do in two hours.
Apparently there’s also an update for software that helps fix this issue. However I didn’t wanna mess around and be caught somewhere I have to leave the car. So I just replaced it.
When it was faulty, I could hear a solenoid trying to activate in the rotator unit every time I press the brake pedal but it would not release, it worked after day or two later however wasn’t willing to take the risk going forward. 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
Post #606958 21st Sep 2021 12:22am
