![]() | Home > Technical (L322) > 2004 Range Rover 4.4 petrol/lpg coolant leak - help needed |
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 208 ![]() ![]() ![]() |
This may be of use;
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
That's the coolant manifold to heater matrix return hose adaptor.
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Part number JHC000081. Cost £7.31 back in 2013 from a main dealer... the parts man at the time said it has a lifespan of around 10 years on average.
Knightrider Member Since: 22 Mar 2014 Location: England Posts: 125 ![]() ![]() ![]() |
Hi thanks for the advice guys, yes that's the part that's leaking. Glad to see it's inexpensive. @steptoe what was the procedure to change it? I'm guessing it's just 2 connections to remove and then put the new one on and top up coolant and bleed? What are the connections used? 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
It’s a simple push fit connection. Then top up and bleed cooling system. |
Hi just to give closure to this thread I got the part and it was a pretty easy fix in the end. The leak has now stopped and the old girl is back on the road. Thanks a lot steptoe and vs322 for your invaluable advice 👍🏼 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
Glad you got it sorted! Happy days |
