![]() | Home > Technical (L322) > Battery light on dashboard |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2282 ![]() ![]() ![]() |
I had this with a cheap aftermarket alternator- please tell me you went denso ? Current stable:
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Sounds like the alternator is on its way mate. My airbag light come on with mine. Scanned it with iid and it said airbag low voltage. Check the battery before you start it up next time n see what's going on |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
Put a multimeter on the battery before starting and then again with engine running. Should be over 14v with engine running. Check belt tightness as well to see if slipping. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
bigfatbloke Member Since: 08 May 2018 Location: London Posts: 40 ![]() ![]() ![]() |
Thanks for the heads up gents. This info gives me an idea of where to start.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
I would also be inclined to check the connections to the alternator and battery for tightness. |
