![]() | Home > Maintenance & Mods (L322) > L322 RR ABS sensors all the same? |
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 207 ![]() ![]() ![]() |
Microcat shows different parts front & rear. |
rich nz Member Since: 01 Dec 2020 Location: Oxford Posts: 4 ![]() ![]() ![]() |
Thanks, I used for the front SSF500011 (green) and SSF500021 (blue) for the rear. But the rear did not function. So ordered another set. The originals on the car were all green. Are these the correct numbers? Remembering that the TDV8 uses a different ASB module to the petrol engine vehicles. |
I cant tell from microcat if those are the correct numbers as mc lists an item number, not the part numbers.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1382 ![]() ![]() |
don't believe what ebay tells you , I fitted abs sensors years ago according to ebay and they were the wrong ones , they change from diesel to bmw spec to jag s/c specm , best to order correct one by vin number |
The "faulty" ones were supplied by Britpart and All makes. front green and blue rear.
I wonder if it might be more important that the sensors are consistent with each other rather than the values they give? Would be interesting to see if there is any change with 4 sensors from the same brand. |
That's where I started on this project. I used all Siemans sensors from my petrol vehicle. |
