![]() | Home > Technical (L322) > 09-12 Headlights?? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8718 ![]() ![]() ![]() |
Mine has AFS and Cornering headlighs, I imagine a brace of ECU's to help them on their way but can't help with the technical side really...!!! Pete
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Would you mind sending me your VIN? Via PM?
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2727 ![]() ![]() |
The VIN won't identify part numbers, only build features. |
I was going to put the VIN into parts catalogue. Will show the part numbers applicable to that vehicle. |
I hadn't thought of trying to use the VIN that way but having just put mine's VIN into Microcat 2012 it still shows both headlight options, not just what's fitted to mine. |
The part numbers are shown in Microcat. The electrical diagrams show an AFS module some distance from the headlights as the wire lengths between the AFS module and the headlights are several metres. If wires exist in pins 5, 7, 13 and 14 of the headlight connectors then the wiring for the AFS module is installed.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
A UK 12my would have only 2 options. With or without AFS, now on 12my (black internals), the non AFS headlamps had the cornering lamps deleted/painted black! So, if you find a black internal 12my headlamp with chrome cornering lamps then it's highly likely to be a Highline lamp... Check the wiring plug to confirm its a 16 pin ??? (I think that's the right number)
