![]() | Home > Technical (L322) > Clunk / thump heard and felt shortly after pulling away |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Hi guys
Oh, and to add…
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
I’d put money on it being the gearbox, struggling to get into a certain gear, could be just low on oil, especially if it’s been done before, may not have been done correctly.
Cheers TDV8 Paul
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1332 ![]() ![]() ![]() |
Keep looking for the cheap stuff. I've just had a quote from Stephens engineering for £2500 +vat to have the gearbox and torque convertor refurbed. I asked if they've done one before and the answer was 'plenty'. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3308 ![]() ![]() ![]() |
Mine also and getting a gearbox service done later in the week. £2500+ VAT seems quite reasonable for a rebuild considering what’s involved……. 2012 TDV8 Vogue (L322) |
Urgh, £2,500 is a bit much at the moment. I have a few jobs needed on the car, plus it’s Christmas time soon so funds are tied up there!
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Have a look at the center bearing on the propshaft, if the rubber support around the bearing is shot it could be causing the intermittent clunk. |
klj Member Since: 24 Aug 2019 Location: Frozen North Posts: 66 ![]() ![]() ![]() |
All of the above plus check epb. After a night long application sometimes the shoes stick after I've released the epb. Then within a few meters I hear a clunk as the shoes unstick. ----------------
Cheers discotigger. I’ll take a look over the weekend!
The center bearing on the propshaft was shot on my 2012 4.4 TDV8 and I would get a random clumk when driving as the propshaft bearing would bump against the bearing carrier. I also got a rumble when accelerating hardish or when cornering. If that's the problem, you can either get a whole new propshaft or just get the center bearing replaced. The propshaft splits into two so replacing the bearing isn't too difficult a job. I just got the bearing replaced by my local indy mechanic.
ottoknows Member Since: 22 Aug 2023 Location: Indonesia Posts: 10 ![]() ![]() ![]() |
Thanks for your advice Discotigger. By any chance, do you know how this "clunk" sounds like? I have been experiencing this "clunk" at low speeds, especially when the RPM is picking up in the 1st and 2nd gear. Usually this "clunk" is experienced in harmony with the slipping of the accelerator - meaning that the pedal will not depress and slips when this "thump-clunk" occurs. At higher speeds around 40-50 km/hr, this is non-existent. Only when the RPM drops, will this "slipping effect" occur. At what mileage did you changed the propshaft bearing? Any other signs when this propshaft bearing is failing? This clunk is intermittent, and does not happen regularly. Thanks for any advice in advance. |
