Home > Technical (L405) > front diff oildrain
fenair
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
front diff oildrain
Morning, L405 2015 SDV8 , Am i being thick here, is there a drain bung in the front diff, i see the filler but cant see the drain, so i am assuming the oil is sucked out of the diff through the filler? any pointers appreciated. Smile Pat
Post #606784 19th Sep 2021 10:23am
Baltic Blue
I am not lucky enough to own a L405, so can’t verify, but the workshop manual ( which is available as a free download from the wiki ) clearly shows separate drain and fill plugs.
Remember to remove the fill plug first…. Just in case.
Post #606785 19th Sep 2021 10:37am
fenair
BB many thanks, it must be in there deep as i couldn't visually detect anything so likely full of debris, now you have been kind enough to point me in the correct direction i can conclude the transmission service, the gearbox fluid is a messy job, the D3 was a good set up with the oil cooler pipes easily accessible to do a mega flush in one go, 3 liters at a time then a run is not the greatest idea, but better than a £4k gearbox and a lot of sweat and tears.. thanks for the info, much appreciated. Pat
Post #606786 19th Sep 2021 10:43am
knwatkins
You need to remove the brace first.
The drain plug is covered by the face of the brace Wink
 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #606795 19th Sep 2021 1:05pm
fenair
Yep its obvious when you look at it.. all done , both diffs and 6 liters of auto box fluid and new filter pan many thanks for the information 😊
Post #606806 19th Sep 2021 3:25pm
knwatkins
Definitely worth doing Thumbs Up
Don't forget your transfer box fluid Wink Kev
Post #606807 19th Sep 2021 3:26pm
fenair
Yep done... It's off to duckworth Boston to have a 60 month service , can do it myself but best just to keep the service records upto date.
Post #606808 19th Sep 2021 3:29pm
kungfupanda
United Kingdom 2014 Range Rover Vogue SE TDV6 Mariana Black
Not sure why it’s different on my 3.0 TDV6? Seems more straight forward on mine.
Anyway, got my hands dirty and did both diffs and transfer case last week.
Post #606823 19th Sep 2021 7:20pm
Fifth Horseman
For some reason the brace is not fitted to the V6 although the mounting points are there.
Post #606842 20th Sep 2021 5:25am
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Related but kind of hijacking the tread. Did I dream there was a forum member who drove all around the country to complete this work on people’s drives. Need to get all my fluids done as just passed 80k and deciding how best to arrange as useless with spanners. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #607167 23rd Sep 2021 11:15pm
knwatkins
You're probably thinking of Bodsy - 07770638023 Kev
Post #607171 24th Sep 2021 6:45am
