Home > Maintenance & Mods (L322) > Vogue td6 intermittent misfire worse on tick over
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
So I have a misfire on my TD6 it’s intermittent sometimes when cold sometimes when hot. No smoke and no fault codes or lights on dash. No noticeable drop in power but when it occurs there is a lot of vibration when ticking over. Still starts fine and pulls ok on acceleration. I am thinking it may be the injector loom and considering changing that first. Has anyone changed one ? How big a job is it?
Any helpful suggestions appreciated.
Thanks in advance.
Post #606955 20th Sep 2021 10:52pm
kevinp
Do a search for Wheeler Dealers Series 10 Episode 3. I can't find an actual link to it though.
Post #606959 21st Sep 2021 1:11am
horsedentist
Yes tried that says it’s been removed
Post #606966 21st Sep 2021 11:39am
IIRC it was a pretty easy job, the loom goes back to the water tight box under the bonnet, lay the new one in place and it should be pretty obvious what you have to do... Thumbs Up
Edit, Pretty sure that one had a misfire fault code showing though...
Maybe worth some diagnostic time with live values.... Pete
-Click here for Thread-
Post #606967 21st Sep 2021 11:50am
horsedentist
Thanks Pete
Post #607004 21st Sep 2021 8:05pm
