Home > Maintenance & Mods (L322) > Front airbag struts
Danwilderspin
Front airbag struts
Hi all apologies if this has been covered - my front struts are a bit bouncy so I was going to replace the pair.
What are the best value for money to go for? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #603075 7th Aug 2021 9:16am
Delphi are OE, I've read you should keep away from Dunlop as they don't last, as for the rest, it's really had to decide...
With something like a strut I'd err towards genuine/OE, at least you know they will work as they should and last a decent length of time, especially if you are keeping your fatty for a while...
Just my 2p....
Thumbs Up Pete
-Click here for Thread-
Post #603078 7th Aug 2021 9:28am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Go for genuine mate or a not so well one will play on your mind in blowing out on the m1 at 70mph
Post #603082 7th Aug 2021 10:00am
Danwilderspin
I’ll go delphi or bwi as they are both oem i believe Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #604147 18th Aug 2021 10:58pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
I went with Arnott, 6 months on and very happy so far.
Had Dunlop. No clue when exactly fitted. The rubber part was still very good but the shock absorber was knocking most of the time. Worked well enough to pass the MOT but I couldn't live with the noise.
Post #604177 19th Aug 2021 12:17pm
Weegie
@VS322
Bit late to this but I have an Arnott strut to be fitted. When other makes have been fitted it emphasises NOT to change the air line fitting.
However, the Arnott instructions suggest the opposite saying the have already installed the fitting and it is a question of removing the olive etc from the airline and using a push fit to install the airline (whichis what I did with the Discovery 2 rear airbags).
Did you have similiar fitting instructions and is that what you did? John
GAP iiD BT-Sold
Post #606984 21st Sep 2021 5:00pm
vs322
@Weegie
I used the existing fittings i.e. the old ones. They fitted just fine and kept the Arnott as spares. Haven't had any leaks in 8 months...
Arnott says that you remove the old fittings and all you have to do is remove the shipping cap, stick the air line into the Arnott fitting which is ALREADY tightened, then pull back a bit to secure.
As I didn't have any leaks, I decided not to mess with the fittings and kind of ignored the Arnott instruction. So I either got lucky or it doesn't really matter.
Post #606992 21st Sep 2021 6:06pm
Merchy
Dunlop items fitted to my 2006, no complaints whatsoever, made in the UK and prices are reasonable as well.
To quote haylands - just my 2p........ Folks will have their own favourite brand. Thumbs Up
Post #606993 21st Sep 2021 6:12pm
Weegie
@vs322
Thanks for that. 👍. It worked fine on the D2 so might go with their view. John
GAP iiD BT-Sold
Post #606994 21st Sep 2021 6:22pm
vs322
@Weegie
You can't go wrong! Thumbs Up
@Merchy
I was genuilely impressed by the Dunlop airbag condition and quality. I can't rule out the possibility of someone having gone to town with an impact wrench on the strut at some point. I might take it apart one day as an autopsy...
Post #606996 21st Sep 2021 6:29pm
