Home > Maintenance & Mods (L322) > Compressor refit on 2004 L322
Snapcap2
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi,I’m about to replace the compressor on my L322. How do I disconnect the airline.Is it a twist and pull action using grips of some description?
Post #607034 22nd Sep 2021 5:51am
Put an open ended 6mm spanner over the plastic airline next to the coupling and press it sideways against the coupling. This will press in the small collar. At the same time pull the pipe out of the fitting.
To refit the pipe simply push in the pipe until it can’t be pushed in further. Thumbs Up
Post #607036 22nd Sep 2021 8:05am
