![]() | Home > Maintenance & Mods (L322) > What voltage means buy a new battery (TDV8 4.4) |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
Funny you should ask this as it was asked on the RRS forum today too.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3329 ![]() ![]() ![]() |
That’s very helpful! 2012 TDV8 Vogue (L322) |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Those look about right for FFRR.
Treebor99 Member Since: 07 Feb 2021 Location: Rugby Posts: 34 ![]() ![]() ![]() |
The only way to apply the posted voltages is to remove the battery from the car, charge it, then leave it a while say a day - then measure.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 782 ![]() ![]() |
I treat batteries as a service item on any automatic car, you can't bump start them and jump starting can be a nightmare. Even an AGM battery doesn't cost much more than a tank of fuel so if you've got even the slightest doubt or are uncertain of it's age I'd suggest replacing it. |
I too agree with the comments above.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
I have an LED voltmeter I have plugged into a cigarette lighter socket in the central glovebox. Shows between 12v and 12.2v with engine off. Between 14.3v and 15v when driving. Higher charging voltage when coldest !
The genuine LR AGM battery is an Exide EK950, with a Land Rover logo on the sticker |
After monitoring voltages and seeing how awkward it is to physically change the battery I think for peace of mind for a dead battery one morning when I have to be somewhere I’m just going to get a Nocoboost starter battery. 2012 TDV8 Vogue (L322) |
