Home > Technical (L322) > TD6 Gearbox or drivetrain?
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Just been out on a short trip to the shops, got back in the car, drove out of the car park and the car groans and takes a dive as though the brakes have been applied. Carry on diving and all good. Slow down to take a turn and again feels like the brakes have been applied as it goes into 1st gear. Get home and check transfer hi low ok. Engine running sweet, Drive slowly forward and the same scenario every time, Get up speed a bit and all seems ok. Any Ideas? The gearbox has done 70000k since a rebuild, No dash warnings or bongs. this could be the end of this old girl. I have run live data and no codes from gearbox, can select any gear in sport mode 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #607170 24th Sep 2021 5:19am
Merchy
First thing I would check is to see if any of the brake callipers are seized, I had the same problem, once at a good speed the momentum overcomes the binding brakes, but at low speed, like you, I thought the drive / transmission was faulty, as the car slowed down at quite a rate. Found both my rears to be seized. Hope this is the problem Thumbs Up
Post #607174 24th Sep 2021 8:55am
wayneg
100% not brakes binding, car rolls with no binding. The feeling is more like something grabbing in the driveline, at 1st I thought I was caught up on something. No nasty noises but more of a groan from the drivetrain, a bit like changing down in a manual and letting the clutch up. I am clutching at straws and keep reading about solenoids and valves in the gearbox failing and springs breaking but cannot find anywhere the same symptoms. Any gearbox experts, know how 1st and possibly 2nd gear could cause this without throwing any codes 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #607179 24th Sep 2021 9:27am
Merchy
All I can think of now is to have a look under the car to check all bits / drive shafts / support bearings etc are in place as normal ( maybe check all oil levels )and if so speak to a gearbox company for advice.
RRphil is the main guy on here for gearbox advice, he may be along at some point. Sorry I can't think of anything else at the moment.
Post #607180 24th Sep 2021 10:17am
Pjtaroni
You haven’t accidentally pressed the hdc button have you? My old man valeted my first Range Rover a few years back, I got in and went to pull off and it did what you have described!
Post #607241 24th Sep 2021 6:40pm
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
You beat me to it pjtaroni lol.
You probably hit the hdc button Wayne.
I,ve always got the dogs in the car whenever I go out and when I let them out for a pee and sniff around,
I occasionally get the sudden stopping when I take my foot off the go pedal. One of the dogs has accidently hit the hdc button and I come to a grinding halt. Laughing
Check that Wayne and see if it goes away,otherwise cant help you.
Post #607256 24th Sep 2021 10:07pm
wayneg
So last night unable to sleep with worry, I mentally removed the gearbox valve body and also wrote a for sale add, spares or repair... then I woke up. Checked for FF replies and got the HDC advice. Rushed to the garage started the car, stupidly did not look for the green downhill logo lit before playing with the HDC and traction control buttons. Ensured HDC off and gingerly pulled out of the dive with no repeat of the grabbing. Went for a 5min drive stopping and starting and all good. Thanks so much, Pjtaroni, littlecub and Merchy for the advice. Of course, I have blamed the wife, Could not possibly be me with all my years of RR experience.
One question I can see that if the HDC is on and I turn off the engine and remove the key then restart the car the HDC remains on. If I left the car overnight will it still be on or does it go off on its own 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #607262 25th Sep 2021 1:29am
Gsxr1250dave
My wife did this last week driving my fullfat, it happens. She called me very upset that she mite have broken my car.
Post #607276 25th Sep 2021 9:06am
Merchy
Good new Wayne, no more dreaming about breaking the fatty Thumbs Up
Post #607287 25th Sep 2021 12:06pm
