Home > Maintenance & Mods (L322) > L322 Gallery Pressure Not Decreasing [VIDEO]
theanswers
Ireland
Hi Folks.
OK, as some of you know I've been having trouble with the air suspension on my 2008 L322 3.6 TDV8. Basically it won't vent the gallery.
I've replaced the following parts and still not luck.
- All Three Valve Blocks
- Compressor & Exhaust Valve.
What else could it be. Height sensors are all OK. I've made this video that shows the problem.
Post #607203 24th Sep 2021 2:16pm
theanswers
Ireland
This is the Error Code which I receive.
Post #607204 24th Sep 2021 2:25pm
I’ve got a slightly different issues in that my error is “reservoir filling too slowly” but it can raise up and down after I reset the error and hit the up/down button but that then says “vehicle lifting slowly”. After much investigation, it looks like my reservoir has a leak, so I’m awaiting a replacement from Duckworths today, so I share your frustration at the complexity of this system. Got - 2017 SDV8 Autobiography in Loire Blue
Post #607209 24th Sep 2021 3:32pm
theanswers
Ireland
I hope you're problem has been sorted! Apologies for my slow response. I'm still trying to get mine fixed!
Post #622381 3rd Feb 2022 9:46pm
I did indeed get it sorted, it was the reservoir tank, had a huge leak Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #622384 3rd Feb 2022 10:20pm
theanswers
Ireland
Well that would certainly cause it to fill slowly!
i'm hopeful I should have mine resolved shortly.
Post #622424 4th Feb 2022 11:17am
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Check the cables going in to the enclosure - make sure none of them have rubbed through and cause a short.
Ask me how I know! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #622615 5th Feb 2022 8:17pm
