![]() | Home > Maintenance & Mods (L322) > Towbar - Westfalia - chassis brackets - 2007 TDV8 |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
They have to come off. They are not part of a towbar and there is no way to convert them. The holes appear to be purely decorative. They only provide the towing?tie down ring.
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 105 ![]() ![]() ![]() |
Many thanks for clarifing that!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Good luck in your search, rumour has it that there is either a production issue or they have stopped producing the Westfalia bars.
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
The early ones can be used on the later ones - you just need to cut the exhaust hangers off the existing brackets that you remove anyway. These can then be bolted on as part of the armature installation.
The Swede Member Since: 30 Apr 2017 Location: Zurich Posts: 3 ![]() ![]() |
Also fitted a Westfalia to my 2008 3.6TDV8. Was a straight bolt on, to be honest. |
Evo290 Member Since: 22 Oct 2020 Location: somerset Posts: 6 ![]() ![]() ![]() |
Try CWS 4x4 at Glastonbury. I got one a few months back for my 07 Vogue SE. They supplied electrics pack as-well. Good price, cheaper than certain auction sites. |
Many thanks to all!
There is a LR part to bung the square hole up when not in use. I did have one but I’m not sure if it got chucked when I moved There is nothing that can't be fixed with a hammer😜😜
