Home > Technical (L322) > 2012 4.4 TDV8 - Steering wheel movements
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
So, it seems that I may have a (small) problem with the electrical movements of my steering wheel.
Can anyone with a late L322 advise on what should be happening in the following instances please:
1. Movement back and fore using the stalk - should it be smooth and continuous all the way, as per my 3.6, or does it need several individual pushes or pulls on the stalk to get the full spectrum of movement?
2. Whenever I switched my 2009 3.6 off, the steering wheel would move up automatically (presumably to facilitate easier entry/exit. Subsequent Ignition On would bring the wheel back down to my pre-set position. Should my 2012 be doing this too, because the wheel doesn't move with ignition On/Off. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #607271 25th Sep 2021 8:50am
rjff
1 Wheel movement shoud be smooth and continuous whilst holding the lever.
2 It's called Easy Entry
Main menu
Vehicle set up
Easy entry
Enter OK and it should operate seat and wheel to max up and down respectively.
HTH Cheers
Richard
Gap IIDBT
Post #607275 25th Sep 2021 9:05am
Weegie
As a first step, have you tried setting it the way you want with the key in ignition and then setting the memory?
It would then be programmed to your key. It may not overcome the problem but, as I said, first step.
If the problem still exists theree is extensive information here: https://www.rangerovers.net/search/552945/...=relevance John
GAP iiD BT-Sold
Post #607277 25th Sep 2021 9:19am
rjff
Errr Weegie
I think JMC has a 2012 and as such it doesn't have a "key in the ignition". Remote fob and starter button instead. Thumbs Up Cheers
Richard
Gap IIDBT
Post #607278 25th Sep 2021 9:28am
JMC
1. That's what I suspected.
2. I know about Easy Entry (have switched it off), but when it was on, the wheel didn't move - only the seat.
Cheers! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #607282 25th Sep 2021 10:45am
rjff
Sorry if I mistook your knowing of Easy Entry.
The wheel should move fully up when EA is on, as mine does. I suspect you have a fault within the column eletrickery bits and that's not something I'm familiar with... YET!
There are threads on the poor movement of the column on here.
search
steering column gear
A few to start
https://www.fullfatrr.com/forum/topic9976....olumn+gear
https://www.fullfatrr.com/forum/topic5754....olumn+gear
https://www.fullfatrr.com/forum/topic37997...olumn+gear
HTH Cheers
Richard
Gap IIDBT
Post #607283 25th Sep 2021 11:06am
DrRob
Switched my EA off on Day 1. Column motor is a known weak point. Useless feature for me Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #607286 25th Sep 2021 12:04pm
Weegie
rjff wrote:
Errr Weegie
You guys with your new fangled cars. Laughing John
GAP iiD BT-Sold
Post #607288 25th Sep 2021 12:16pm
JMC
No appologies needed rjff. Thanks for the links! Thumbs Up The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #607315 25th Sep 2021 8:25pm
JMC
So, just to be clear, my steering wheel moves in/out/up/down, but the in/out only works with several pushes/pulls of the lever. The up/down works all the way with a single push up/down of the lever. It goes all the way in and all the way out, but I have to do half a dozen pushes /pulls on the lever to acheive this. It just moves a small amount each time and then stops.
Also, the wheel doesn't move up out of the way when the ignition is switched off, nor does it move when lazy entry/exit is activated. It also doesn't move with the memory button, while the seat and mirrors do.
In other words, it's certainly not a 'problem' as it doesn't bother me in everyday use, but it's not doing what it's meant to! Rolling with laughter The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #607318 25th Sep 2021 8:35pm
Put it where you want it, leave it alone.
I Never moved mine, just incase it packed up in a not good position.!! There is nothing that can't be fixed with a hammer😜😜
Post #607319 25th Sep 2021 8:43pm
JMC
That's what I've done. Wink The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #607320 25th Sep 2021 8:47pm
