![]() | Home > Maintenance & Mods (L405) > L405 inverter install |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
A much better alternative is to use a 12v charger for these batteries.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8055 ![]() ![]() ![]() |
If you're going to do it, then depending on the size of it, there may be an obvious location -
150 amp 12v feed also required….. BMW i3 Electric Car
Likeomg Member Since: 15 Jul 2021 Location: Newcastle / Keswick Posts: 31 ![]() ![]() |
Im charging big packs and lots of them so have quite a bit more powerful chargers than the above, one boat runs 14s2p usually for 3 mins run time. so 14s 10,000mah... I have one on 12s2p (16,000mah) my charging setup is designed around a 240v input... |
This makes a lot of sense - i bought a L405 2 months ago now and haven't seen it.. Still bobbing around offshore. |
Now i know the battery is in the back, very easy install, it will just be a temp thing so it will be case of running two cables and leaving it loose in the back. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
thats the auxiliary battery that is shown in Alistairs pic...you may have one or you may have a capacitor..
As Stan says, the main battery is under the compressor, under the spare wheel - I've got an Andersen connecter permanently wired to mine in case I need to connect it to anything.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
And if your car does NOT have rear AC & heating then the LHS cubby will be empty |
I believe it has rear AC & heating, its a 2015 AB but again - i sent my farther to test drive & buy it as im overseas.
