Home > Technical (L322) > Rear locker fitted or not?!
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I'm going to change my diff oil so in order to get the right oil I need to know the type of diff.
I got in the car and selected an off road, low ratio program and my dash and the audio unit show two different things.
The audio unit shows a padlock over centre and rear diffs, the instruments just shows centre.
Anyone got an idea why this is ans how I can actually confirm the diff fitted?
Post #607367 26th Sep 2021 10:38am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
I've been wondering the same thing, as I'm seeing exactly the same on my 2012 Westminster. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #607414 26th Sep 2021 3:52pm
rjff
Try entering your VIN into
vindecoderz.com.
You will get a build spec which may answer your question.
Failing that have a chat with Rob at site spnsors Duckworths tomorrow.
HTH. Cheers
Richard
Gap IIDBT
Post #607416 26th Sep 2021 3:56pm
mjdronfield
Looks like it’s not got it.
When it’s been mentioned before, it was found the graphic shows on the centre screen even if it’s not fitted. It always shows an open one, and never locked, as it’s not fitted.
If it’s fitted I believe it will change from open to locked on the central screen, and also show correctly on the instrument cluster.
If you want to know for sure, crawl underneath and the locking one has an electrical connector on the diff.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #607427 26th Sep 2021 4:36pm
^ wot that man said. Crawl under and have a look. Open diff has no connector locker has a plug, wire and iirc a solenoid on it. There is nothing that can't be fixed with a hammer😜😜
Post #607430 26th Sep 2021 4:43pm
mjdronfield
https://www.fullfatrr.com/forum/topic47819.html?highlight=locking
https://www.fullfatrr.com/forum/topic41994.html?highlight=locking
https://www.fullfatrr.com/forum/topic39473.html?highlight=locking
https://www.fullfatrr.com/forum/topic33692.html?highlight=locking
https://www.fullfatrr.com/forum/topic20686.html?highlight=locking 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #607432 26th Sep 2021 4:44pm
Caesium
Got underneath and had a look, no actuator.
Now I need to track down the oils for the diffs and transfer case
Post #607433 26th Sep 2021 4:48pm
