![]() | Home > Technical (L322) > 4.4 TDV8 total electrical failure |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
Sounds like the alternator has packed up.
Spike Member Since: 23 Sep 2019 Location: Northants Posts: 17 ![]() ![]() ![]() |
Thank you, would alternator fail drain the battery instantly? The AA on on the way!! |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2690 ![]() ![]() |
A flat battery will occur within a very short time if a diode fails short circuit. |
Do alternators on this engine show any warning signs before they fail ( weeks / days and not seconds) or have an average mileage fail distance? 2012 TDV8 Vogue (L322) |
Thanks for your help on this, AA man thinks it's a short at the back of the alternator, apparently access is restricted from above so he can't tell exactly, on a recovery truck now, it drained his power pack instantly then when ho hooked her up with jump leads there a smell of burning so switched straight off, I will let you know the outcome. Cheers |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
I reckon alternator has gone and taken battery with it. Always put a new battery on when a new alternator is fitted. 019 AGM on a 2011 4.4 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
The power diodes used in the brand of alternators that LR use are avalanche (Zener) diodes used to prevent excessive over voltage, a condition that can occur if for example the battery becomes disconnected while the engine is running. These diodes have the characteristic that once their trigger voltage is reached they reverse conduct, thereby causing an instant reduction in voltage. The problem is that as the diodes age, which is accelerated when they've been working close to their current capacity, is that the trigger voltage lowers eventually getting down to battery voltage at which point one or more reverse conduct causing an almost dead short. Because LR attach the alternator's output cable to the starter cable, the much higher current capacity of the fuse on the starter cable won't blow when the alternator diodes short circuit back through the windings.
Just to update, he picked her up yesterday and indeed ''twas the alternator" they checked and said battery was fine so didn't change it, £600 bill apparently they are very awkward to do, thanks for your input. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6799 ![]() ![]() ![]() |
They are awkward to replaced but a £600 bill is actually pretty reasonable |
Parts are cheap on these engines (it's a Ford!) - it's the labour involved in fitting them that's expensive! I'm sure the garages actually prefer working on D3/4/RRS where you can just lift off the body to get at everything?
