Home > In Car Electronics (L322) > Additional anti-theft measures
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
What do people think of additional theft prevention devices?
Have many people bothered to fit them?
I have a CAN-BUS immobiliser on my M4 and was considering putting one on the RR just in case. Are people still stealing the old ones or are they more interested in the newer models now
Post #607493 27th Sep 2021 10:11am
Merchy
From what I have read, the cars most likely to be stolen are early classics and L405's, but it would give you peace of mind which is priceless. You also appear to live in an area more susceptible to car theft than my North Wales location, so over-all a good idea, go for it. Thumbs Up
Post #607516 27th Sep 2021 4:27pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Just who in their right mind would steal an L322? Whistle
Seriously now, a steering wheel lock, as cumbersome as it may be, it's one mighty deterrent.
Post #607545 28th Sep 2021 7:11am
GGDR
Kill switch is easy to add and hide
also consider OBD protection of some sort
. Cheers, Greg
Post #607584 28th Sep 2021 1:38pm
TJH1985
My old defender had the ODB wired up so that the positive and data cables were reversed..... Evil or Very Mad
It was pretty scary, you could literally turn off the immobiliser etc with just access to the ODB port.
Rolling with laughter Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #607602 28th Sep 2021 3:50pm
RRTurboD
Australia 2002 Range Rover HSE Td6 Zambezi Silver
Greg, you suggest a kill switch ....
What do you suggest should be disconnected by the hidden switch?
On my RRC I killed/switched off the electric fuel pump, (switch in ash tray on back of centre console) car would start, but any more than idle would die. Used a double pole switch, and had a bright flashing LED on dash active when pump off. Seemed to keep repairers guessing, when I forgot to not activate it when I dropped it off at their workshop! 2002 TD6 HSE
1988 RRTurboD RIP (Tdi300, Auto, X-Eng suspension, now operating as a farm fire truck)
Post #613510 23rd Nov 2021 11:54am
GGDR
tons of options, you can be creative...
-if you have a 4.4TDV8 with the rotary controller you could pluck a cable from the transmission loom.
-there is also a small cable running to the battery
-or how about the push button start switch
. Cheers, Greg
Post #613513 23rd Nov 2021 12:20pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
As a comment ref items like Diskloks - which superficially look quite effective :
They cost an efficient thief around 20 seconds max to remove !
There was a video of one being removed as part of a car theft that was recorded via CCTV on a local Facebook group.
The thieves were equipped with a cordless anglegrinder - which had it removed that fast.
However, I'll still carry on using my Disklok - as the 20seconds & the associated noise is possibly enough to make another car more "attractive" to the thieves - as so many owners do absolutely nothing to prevent loss.
I can't believe how many locals near me don't even use faraday pouches for their keyless car keys & then wonder why their car gets nicked Rolling Eyes Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #613545 23rd Nov 2021 4:07pm
One that takes seconds to cut through with a battery grinder! Think about how quiet your car is with the doors closed, for the 20-30seconds it takes to cut through! Far better to get an immobilizer sir...
Post #613582 23rd Nov 2021 9:50pm
JamesDarby
United Kingdom 2011 Range Rover Autobiography TDV8 Buckingham Blue
Any one got a recommendation for a good immobilizer then having just bought my first FF I don't want to loose it!
For a 2011 TDV8
Post #613637 24th Nov 2021 12:08pm
Ashley
United Kingdom 2011 Range Rover Westminster 4.4 V8 Orkney Grey
just had a Ghost fitted to my 2012
Post #613651 24th Nov 2021 12:39pm
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Ghost is quite pricey though, huh. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #613667 24th Nov 2021 2:21pm
ur20v
A Trap
Unless your insurance company recognizes and gives you a discount or lowers the excess is it worth spending a lot on security?
Quite often dealing with an attempted theft and the damage done can be as time consuming as a complete loss 🤷
Theft isn’t that common statistical so unless a vehicle is irreplaceable Just follow normal safety protocols like never leaving anything in the car especially on display, try and keep off the road, shut gates better still in a shut garage and always lock it etc.
That said If you have your own driveway you can get a drop/fold down bollard… just consider any security device can cost time and convenience which you have to way up, a lot of devices like steering wheel locks, wheel clamps etc just become an annoyance and most people will simply just stop using them.
Post #613695 24th Nov 2021 5:38pm
Caesium
You can get exactly the same type of unit from ampire.de at a 1/3rd of the cost if you're good with a soldering iron. Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #613697 24th Nov 2021 6:02pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Its an L322, they are very cheap vehicles. Insurance and the standard security is plenty sufficient...I'd rather have them take it to be never seen again than being thwarted in their attempt, and have damage created in the mean time and being uneconomical to repair which they will be at the age they are now.
To me this is unnecessary...
Post #614606 3rd Dec 2021 4:24pm
