![]() | Home > Maintenance & Mods (L405) > Full Filter And Fluid Service Done - Nearly |
baisong Member Since: 22 Nov 2019 Location: MA Posts: 4 ![]() ![]() ![]() |
May I ask why you changed Dynamic response reservoir? Is the Dynamic response filter in there? Thanks |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
Yes Kev
Thanks very much!
https://drive.google.com/open?id=1aSE85XAU...JN27BjS3Pd Kev
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
I'm guessing you don't have the ZF 8 speeder then? That oil is about 40 quid a litre. |
Yes, I the 8 speed ZF is the only gearbox available for the L405.
That is worth knowing.
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 133 ![]() ![]() ![]() |
HI Caesium
Autodoc. |
rk7 Member Since: 18 Sep 2024 Location: Oxford Posts: 18 ![]() ![]() ![]() |
Hey knwatkins, Apologies for reviving this old thread but did you have any adverse affects after using the Mannol ATF oil in the long run? I'm just about to do this but reading a lot of shady stuff about Mannol. I personally think they all use the same recipe to make these oils but still wanted to double check if it's worth going for the more premium stuff. Thanks, RK |
Deleted |
Hello, the Mannol AG60 has been fine. I did another few drain and refills in August 2024. My L405 is now on 120k and still silky smooth as it should be.
Thank you for confirming. |
